    Suunto ZoneSense
    966 Posts 149 Posters 220.7k Views 126 Watching
    • Stefan KerstingS Offline
      would like to share my first observations her. Did some spinning workouts with 3x5 min intervals. when warming up I was in the aerobic zone. after starting a harder effort within the 5 min interval it took about 2 min to get into the anaerobic zone. After further 2 min i got into the Vo2 max zone. So one minute was left and even when still going string with a HR of 158 i dropped back into the aerobic zone. Have to give it som more tries and observe a little bit more.
      • VoiGASV Offline
        VoiGAS Gold Members @Stefan Kersting
        @Stefan-Kersting How long were your recovery breaks? If they were short I think you saw the expected behaviour
        Edit: Except the breakdown in the end…
        Vertical
          Stefan Kersting Platinum Member @VoiGAS
          @VoiGAS recovery breaks were 5 min
          • SuperFlo75S Offline
            SuperFlo75 Silver Members Bronze Member @enriqueescoms
            @enriqueescoms I have similar experiences with my SV… 🥲 I use the Suunto smart heartrate belt
            Suunto Spartan Ultra
            SA iOS 3.5.1 (20789)
            Instagram @superflo75
            • Francesco PaganoF Offline
              I keep getting interesting insights with ZoneSense.
              Today I woke up with my lowest sleep and resting HR and highest HRV ever. Also when I started running my HR was relatively low compared to the effort I perceived.
              The ZoneSense gauge would slip into the anaerobic zone at a lower HR than expected, around 142 bpm, which can be explained with fatigue from a long run 2 days ago. What surprised me is that every time this happened it was when I felt that little extra push when breathing is no longer effortless. But also, ZoneSense stayed in the green (aerobic) at ±148 bpm while pushing down a hill with little effort and easy breathing.
              To me this means that today my AeT was lower due to accumulated fatigue, and that a higher HR doesn’t necessarily mean I am crossing the threshold (i.e. I am not really spending much effort).
              Obviously my wife says it’s all in my head 🙂
              S9PP
              S5
              Ze StuartZ 1 Reply Last reply Reply Quote 7
              • Ze StuartZ Offline
                Ze Stuart Gold Members @Francesco Pagano
                @Francesco-Pagano see my post above, confusingly linked below: @the_ultraman found a note in the Facebook community saying there’s a bug in the watch analytics, fix soon…
                Or your wife is correct and it’s in your head, but that’s a dangerous thread to follow that ends with the downfall of the whole sports analytics industry!
                https://forum.suunto.com/post/154337
                https://zulusierra.co
                • Raimo JärviR Offline
                  Raimo Järvi @Ze Stuart
                  @Ze-Stuart said in Suunto ZoneSense:
                  @Raimo-Järvi I believe you are a deity of S+, do you have a date you can share for the fix?
                  I don’t work for Suunto any more, I’m a mere mortal now 😁 I don’t have any additional information about this, but if Janne says it will be fixed in “upcoming mobile update”, I guess the fix is in Suunto (mobile) app and not in SuuntoPlus.
                  Pragmatic Programmer
                  • enriqueescomsE Offline
                    enriqueescoms
                    Updated.
                    My 33% 25% “good experience” with ZONESENSE.
                    (Suunto 9PP + PolarH10 heart belt / IOS App v2.38)
                    The last few days I have tried Zonesense three four times with the following performance results:
                    1. Mountain bike. No route tracking. Autopause triggered. Guide Structured work. WATCH FAIL (*) / APP OK
                    2. Mountain bike. With route tracking. No pause. No other guides. WATCH OK / APP OK
                    3. Trail running. With route tracking. Pause. No other guides. WATCH OK / APP FAIL (**)
                    4. Running. With route tracking. With route tracking. No pause. Guide Structured work. WATCH OK / APP FAIL (***)
                    (*) On the watch, the zone sense screen only indicated zone 1, regardless of heart rate or effort level, without the zone gauge moving. Later, however, in the app, the different zones were identified with colors and the thresholds were marked, etc.
                    (**) On the watch, everything worked perfectly, as expected from the Suunto+, indicating the times in each zone, the gauge indicating the appropriate section, etc. But then nothing appeared in the app, as if nothing had been registered.
                    (***) This time it worked well on the watch, pointing out the areas that seemed to be appropriate for the perceived effort and heart rate. However, the transfer to the app does not match what is seen on the watch. The data is only partial and it appears as if there is a shift to the right.
                    Anyway, dispite is a promising feature that hasn’t worked consistently for me yet. In fact I belive there is definitely some error behind it. Otherwise I’ll keep trying over the next few days.
                    Suunto Race S (gravel gray)
                    Francesco PaganoF 1 Reply Last reply Reply Quote 0
                      Francesco Pagano Silver Members Bronze Member @enriqueescoms
                      @enriqueescoms said in Suunto ZoneSense:
                      @enriqueescoms in the App the ZoneSense graph is always shifted to the right since the first 10 minutes are only used for calibration. I hope this is what you’re referring to.
                      S9PP
                      S5
                      enriqueescomsE 1 Reply Last reply Reply Quote 3
                        enriqueescoms @Francesco Pagano
                        @Francesco-Pagano I´m afraid not.
                        On the watch, the Zonesense started working, as expected, after the first 10 minutes of warm-up/calibration. But look at the graph, it starts after the 20 minute mark. Also, it only shows the aerobic zone (100% -18min). Which is not true because it does not reflect the anaerobic zone and VO2max zone, which were also present. And beyond that, it is not possible that the total was 18min when the activity lasted 49min.
                        Something is wrong somewhere. And I can’t find a pattern. Because out of 4 attempts it has failed in 3 and each one in a different way.
                        Thanks, however, for your contribution.
                          The data in the mobile app should be computed by the mobile app itself, not the S+ app, as far as I know. You have the graph and all the other info even if you do not use the S+ app. So, better not to mix the two sides, and discuss the S+ app here.
                          enriqueescomsE Sergei LadeishchikovS 2 Replies Last reply Reply Quote 0
                            enriqueescoms @isazi
                            @isazi said in Suunto ZoneSense:
                            @isazi What do you mean? That it’s a bug in the ios app and I should report it in an mobile app issues thread? Or what? 🙄
                              Sergei Ladeishchikov Bronze Member @isazi
                              @isazi Shouldn’t the mobile app and S+ be the same? By the way, in my case the calculation in the app starts after 10 minutes of warm-up, and in the last long run after 2 hours the graph ends (total duration 3 hours). Could this be due to poor quality data from the heart rate belt? There is no such problem in short workouts up to 1 hour. I use H10.
                              • chee ee jordan loC Offline
                                chee ee jordan lo @Christoph13
                                @Christoph13 hmm doesn’t work for me. I even tried to uninstall and install. I wonder if the latest app version has been pushed to all AppStore’s. I’m in singapore and my app is 2.38.0
                                  isazi Moderator @enriqueescoms
                                  What you see in the mobile app does not come come from the S+ app, so you should report it in the iOS app (in your case).
                                  enriqueescomsE 1 Reply Last reply Reply Quote 0
                                    isazi Moderator @Sergei Ladeishchikov
                                    @Sergei-Ladeishchikov said in Suunto ZoneSense:
                                    Not really, the mobile app can do better filtering as it has the full workout available, so results may be different. The goal is for them to be close enough, and the S+ app should learn the coefficients better the more you use it. This is what I have understood so far.
                                    H 1 Reply Last reply Reply Quote 3
                                    • H Online
                                      halajos Bronze Member @isazi
                                      @isazi do you know if we get an updated ZoneSense S+ or firmware soon, which fixes the issues with using ZoneSense together with other S+ or intensity target, what a couple of us experienced and discussed in the forum?
                                        isazi Moderator @halajos
                                        @halajos some glitches of the app have been reported, and S+ apps can be updated any time without the need for a firmware update
                                          @isazi Well, anyway, could you be so kind as to report this to Suunto as well? I would appreciate it. Thanks. 🙏
                                          • H Online
                                            @halajos S+ apps can be updated any time without the need for a firmware update
                                            I know that, but as in my experience there are interferences between ZoneSense and another S+ app (ultra walking), as well as between ZoneSense and intensity target, I’m wondering if there may be a need to update the “S+ framework” in base firmware.
