 @kolyany4 said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829: If all fails then maybe is hardware but I doubt it is hardware as it would have to be compass, accelerometer or GPS chip, right? If you enter Navigation->Compass, how often watch asks you to perform calibration? How long it should keep its calibrated state? Recently I saw odd behavior on new watch (like I did on old one) in indoor:
 in Navigation->Compass mode: Arrow pointing to North were seems to be stuck (it hasn’t changed its direction though I have rotated my watch) for a several dozens seconds, after that compass recalibration screen has appeared… Don’t know, if this case matters…I do not know either, I rarely use the compass and certainly not indoors as it will not function appropriately in a building. I would test the compass outside, clear of buildings, similar to what you would do for calibration of FusedTrack.
 Reading all these posts, I just remember to ask if there is some strong magnectic field in the area, like a big train interface, high voltage electrical post,…
 I remember when I own a Suunto Spartan Trainer WHR and when I run near by an electrical train interface, the GPS and sometimes even the HR monitor went crazy, for some meters.
 No surgery, No electric lines… However, I feel really extremely stupid and very sorry about what I’m going to say: I forgot about my gloves I love to wear in cold weather:
  To be specific, I completely forgot that it contains teeny-weeny magnetic parts… [facepalm] NB. As an excuse I can say that those often requests for compass recalibration happened indoors as well, and cases, when north pointing arrow on compass got stuck, I get when no such gloves were around me… I’ll do tests today and let you know about results. PS. Most tricky to found bugs are almost always related to things we are most sure of. pps. I’m still banging my head on a wall…
 Just finished another run with all possible magnets stripped off my clothes using Custom Mode with GPS = OK. Preliminary results looks very promising:
 5.03 km (from watch) vs 5.32 km (from smartphone app).
 And, most importantly (for me), start and finish points are located where they expected to be.from watch:
  actual track:
  I’ll keep checking results in next runs… I was wondering, could we avoid all this mess, caused by me, for which I’m really-really sorry, if a watch -
had some kind of ‘use straight line between GPS-acquired-points instead of requesting recalibration action’ option to avoid completely messed track;
had some kind of magnet field detection mode which one could use to check his/her clothes/gear (sometimes rented) in order to find any emanation source that would jeopardize proper work of a watch.
 @Dimitrios-Kanellopoulos , I’m really-really sorry for all inconvenience I’ve caused, but what do you think about ideas above? ps. I’m still banging my head on a wall…
 At least we finally sorted the mystery out.
 by far the most interesting thread in the forum
 @kolyany4
 Out of curiosity, what’s the purpose of the mini magnet? Fastener?@Dimitrios-Kanellopoulos
 This thread should be forwarded to support
 @sartoric said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829: @kolyany4
 Out of curiosity, what’s the purpose of the mini magnet? Fastener?It keeps “finger cover” fixed/attached to outer side of palm when cover is “opened”.
 This cover allows my gloves to be used as mitten (in really cold weather) or glove with opened fingers.
 @Dimitrios-Kanellopoulos said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829: by far the most interesting thread in the forum Perhaps, Suunto support should be notified about following hint: one should use watch in Compass mode (after compass has been calibrated) as a detector of magnetic field or metal construction. Move your watch (with active Compass) in the vicinity of your gear/clothes/whatever. If your watch instead of showing compass will ask you to ‘Calibrate compass’, then you’ve found source of your possible problems with Compass, hence jeopardized FusedTrack functionality, and messed your tracks, as a result, whenever watch will get close to that source …
 @kolyany4 said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829: @sartoric said in S9 (2.4.14) 'Calibrate FusedTrack' interface problem. Suunto Case #01853829: @kolyany4
 This cover allows my gloves to be used as mitten (in really cold weather) or glove with opened fingers.Oh I see … That’s why I like the good ol’ buttons or velcro
 Oh I see … That’s why I like the good ol’ buttons or velcro  Are you sure those buttons can pass given above hint with Compass test?
 @kolyany4 I miss all of the fun when I am asleep:). I have very similar gloves but they fasten with Velcro not magnets… I am happy to hear that the problems may be solved. Magnets on many items these days are very strong and I can see how a magnet close to the watch would disrupt the compass. Good to know.
 Awesome topic
 Good to know, because I also wanted to buy such gloves
 Today had another run. Results are OK (5.33 km vs 5.14 km).
 However, another bug was found. But this one is related to “SA -> Strava” autosync:
 https://forum.suunto.com/topic/1651/3-54-2-sa-strava-wrong-autosync-moving-timefrom watch:
  from smartphone:
  ps. I would make screenshot images to appear smaller in my messages, if I knew how to do it using only forum tools…
 Track looks quite OK
