    No-Map-Problem
    299 Posts 65 Posters 50.3k Views 62 Watching
    • renton82R Offline
      renton82 Platinum Member @Mff73
      @Mff73 Yes, it would be great! I’m a bit disappointed that i can’t see the map without a GPS fix.
      mikekoski490M 1 Reply Last reply Reply Quote 3
        To see the map without GPS you already have your phone, why would I want to see the map randomly on such a small screen? Map’s for navigation on the watch, not to play.
        renton82R ? L Mff73M EzioAuditoreE 6 Replies Last reply Reply Quote 2
        • renton82R Offline
          renton82 Platinum Member @isazi
          @isazi Points of view…
            A Former User @isazi
            @isazi for using your watch, you always need to bring your phone too?
            Browsing quickly on the map to see what is still ahead of you makes perfect sense to me (while indoors warming up, without GPS fix).
              Likarnik Bronze Member @isazi
              @isazi maybe to check if map works for routes on different location (on vacation 1000km away)?
              surfboomerangS 1 Reply Last reply Reply Quote 9
                Mff73 @isazi
                Adventure first. Now maps are there, why limit their usage just to the initial use case. Vertical has map, and potentially enormous battery duration : imagine your phone dying or running out of battery…
                It is not just playing on our couch (yes, today it is), or checking that map download is correct in another area where you won’t have Internet and charger to redownload it, etc…
                So, feature request, just that 😊
                • mikekoski490M Offline
                  mikekoski490 Bronze Member @renton82
                  @renton82 Agree. Would be nice to preview a map on the watch without gps. I don’t always bring a phone and trying hard to disconnect more often.
                  Current: Suunto Race Ti
                    surfboomerang @Likarnik
                    @Likarnik Not only 1000km away. I noticed a map glitch on a route 50km from my home. Only way I noticed it was by following the route and be surprised by it.
                    Even if I had checked it at the location and noticed it right before the start of the route, re-downloading it wasn’t possible because I don’t have a charger with me.
                    Checking it upfront from home would be great.
                    • isaziI isazi referenced this topic on
                    • MiniForkliftM MiniForklift referenced this topic on
                    • EzioAuditoreE Offline
                      EzioAuditore Gold Members @isazi
                      @isazi so redownloaded all the maps including my local area Hessen, Germany. Still black screen. Any clues? 3f7f1b18-7f94-4967-9f3d-e2df37354025-image.jpeg
                      isaziI ChrisAC 2 Replies Last reply Reply Quote 0
                        isazi Moderator @EzioAuditore
                        @Hristijan-Petreski send logs and a PM, I’ll open a bug for you.
                        • ChrisAC Offline
                          ChrisA Platinum Member @EzioAuditore
                          @Hristijan-Petreski maps work flawlessly for me now. Before it was clear, that the maps were faulty, I did a hard reset. Perhaps that helps 🧐
                            @isazi Apparently I had to go for a run first since the reset may have lost my gps? Nevertheless while on maps the watch said it has acquired location but was blank. After run and while running the maps are working fine 🙂 Thanks.
                            • SuperFlo75S Offline
                              Is there any possibility to check if a new map is ok or not before I am there? I will go for holiday to Fréjus and just downloaded the map for the Côte d‘Azur… I‘m not sure if it will be possible for me to download it again when I‘m there… did somebody just use the map there?
                              Suunto Spartan Ultra
                              SA iOS 2.47.3 (19893)
                              Instagram @superflo75
                              • ChrisAC Offline
                                ChrisA Platinum Member @SuperFlo75
                                @SuperFlo75 I tested if you can use your phones wlan hotspot and it worked for me with an iphone. So if there is cellphone coverage, you should be able to download maps to the vertical
                                  dombo Bronze Member @isazi
                                  @isazi when weather on watch can be based on the last gps fix (even 1000km far away from my actual position) why not maps?
                                  • R Offline
                                    Racoon6
                                    Hello, I found a new problem. I went on a long hike yesterday and after the first break, the navigation system kept beeping and vibrating. After about an hour it was over. After the second break the same game again! Battery has dropped from 80% to 55% in 4 hours! Vertical seems to be very bugy!
                                    a276eb44-9488-4539-ba6d-37629a1ee262.MP4
                                    ChrisAC EgikaE 2 Replies Last reply Reply Quote 0
                                    • ChrisAC Offline
                                      ChrisA Platinum Member @Racoon6
                                      @Racoon6 uh thats odd… but I don’t think its a general problem with the watch being buggy. I did a 27 km bike ride (with a two hour break in between) and 10 km Nordic walking- both with navigation - without any maps problems. I guess that adding maps to a ecosystem like Suunto‘s which has worked well for many years without it, is just a big step and also a very complex one softwarewise. So I would anticipate that there will be problems and bugs with that in the beginning, but Suunto normally fixes severe bugs quite fast.
                                        isazi Moderator @dombo
                                        @dombo weather is based on your phone position 🙂
                                          Egika Platinum Member @Racoon6
                                          @Racoon6 is it possible that auto pause was constantly kicking in because of slow movement?
                                          Just guessing, as I have not seen anything like this in many months of testing…
                                          Cheers
                                          • R Offline
                                            Racoon6 @Egika
                                            @Egika Hello, I don’t really think so. Time, pulse, etc. continued to run normally and I had a speed of 5-6 km per hour.
