    No-Map-Problem
    299 Posts 65 Posters 50.8k Views 62 Watching
    • Enrique 0E Offline
      Enrique 0 @Björn Twittmann
      @Björn-Twittmann I had exactly the same problem,during a bike training, map was empty excepted near my home. Then I stopped watch (Parameters --> General --> Stop Watch) and started again the Watch. It solved the problem.
      Björn TwittmannB 1 Reply Last reply Reply Quote 1
      • Björn TwittmannB Offline
        Björn Twittmann @Enrique 0
        @Enrique-0 Thank you so much for helping me. Now it works.
        All the best to you and many thanks,
        Björn
          Tieutieu Platinum Member
          Since I received my vertical, maps where at beginning working pretty well.
          Since then, I have had more and more maps areas that where not displayed.
          Around my place there where first just ok, few days ago certain areas and scales where not visible anymore, and tonight nothing was displayed.
          I m not very worried (Also because I don’t need maps those days), but I’d like it to work again properly. I’ve tried soft reset but no results.
          I’ve tried to stop watch like proposed by @Enrique-0 and it’s seems ok now.
          What leads me to that point : is it like a sort of « cache memory saturation » that could happen when too much maps have used ?(don’t know how to say that properly)
          Enrique 0E 1 Reply Last reply Reply Quote 0
            Enrique 0 @Tieutieu
            @Tieutieu for information, map problem happened again for me today during a bike training 😲 I was not happy at all because I bought Vertical watch for 2 reasons : autonomy and maps ! (and this is not my first Suunto). Then I didn’t want to restart my watch during the bike session, so I decided not to display the map, an later during the session the bike session stopped alone on the watch ! (I specify that the watch is attached to the handlebars and I touched nothing !!!) I was quite disappointed, so my bike session was recorded in two different parts 😞
            All for my point of view this sounds like a bug…
            I wonder if I shoudn’t restart my watch before each sport sessions using GPS where I could need map displaying…
              zhang965 @Enrique 0
              @Enrique-0 said in No-Map-Problem:
              The map feature is NOT ok.
                Tieutieu Platinum Member @zhang965
                @zhang965 said in No-Map-Problem:
                Since I stopped/restarted the watch once, I didn’t had any issue with maps, works fine.
                for sure this issue as to be fixed asap.
                • Jan KrejčíJ Offline
                  Jan Krejčí
                  Tips for everybody: What I do now is I restart watch every time after I’ve synced new routes into the watch. Since doing this, I’ve got no problems at all with bad rendering (black screen with white grid). Also, after the restart I have to calibrate the compass/maps. Better to do it immediately, otherwise you need to dismount from bike handlebar and do it anyways.
                  tazidenT TieutieuT 2 Replies Last reply Reply Quote 1
                  • tazidenT Offline
                    taziden Gold Members @Jan Krejčí
                    @Jan-Krejčí new routes or new maps?
                    S9PP
                    Jan KrejčíJ 1 Reply Last reply Reply Quote 0
                      Tieutieu Platinum Member @Jan Krejčí
                      @Jan-Krejčí said in No-Map-Problem:
                      Ohhh that’s a nice catch about comportment that could lead to the no map pb. I just added a new route into the watch (I had no problems with maps for a while)…I just checked after your message and I have a few black squares back ! Will stop and start it (had done it once and it solved). Thanks !
                      [Edit] => stop/restart. show map, calibrate compass => black squars gone away. took 1min, but hope it will solved with the hot fix to come.
                        Jan Krejčí @taziden
                        @taziden Routes. It is strange but first route on a new map was no problem. Second time though - new route on the same map - I got the rendering problem
                        • mikekoski490M Offline
                          mikekoski490 Bronze Member
                          I’m starting to get this issue after hotfix. About 25% of my workouts get the grid with no map. Anyone else?
                          Current: Suunto Race Ti
                          sartoricS Jan KrejčíJ 2 Replies Last reply Reply Quote 1
                            sartoric Moderator @mikekoski490
                            @mikekoski490
                            did you reload the map ?
                            SVTS - 2.40.38
                            Suunto App Android 5.4.5 beta
                            mikekoski490M 1 Reply Last reply Reply Quote 0
                              mikekoski490 Bronze Member @sartoric
                              @sartoric Yes. I did a complete reset and reloaded 2 maps. Took 4.5 hours. The maps show up sometimes / sometimes not.
                                Sascha Domres Bronze Member @Racoon6
                                @Racoon6 made a trip to cologne today. My watch didn’t show a map although I downloaded the whole of Germany… Soft reset didn’t work… the map works 150 km away in my home town of Hesse… The vertical is really unreliable
                                  sartoric Moderator @Sascha Domres
                                  @Sascha-Domres
                                  did you get a GPS fix ?
                                  SVTS - 2.40.38
                                    Sascha Domres Bronze Member @sartoric
                                    @sartoric yes, there were no problems with the recording… I restarted the clock twice… unfortunately no map to be seen…
                                    • Pablo Bretón GarcíaP Offline
                                      Pablo Bretón García
                                      me the same after the last hotfix. I did a softreset and redownloaded the maps but I can not see the maps
                                        Still no maps for me. Went on a bikepacking trip and did not get any maps for the days away, and just went on a 2 hour local ride from my house and did not get maps again - just the black screen with the grid.
                                          freeheeler @mikekoski490
                                          @mikekoski490
                                          did you try a soft reset?
                                          if so and it didn’t help, please send logs and pm account name and time logs sent
                                            mikekoski490 Bronze Member @freeheeler
                                            @freeheeler Ya. 2 soft resets. One big reset and re downloading of all my maps. They work for a bit, or not. I’ll wait for some kind of firmware update.
